[mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Audaire David
DAUDAIRE at ares.fr
Mon May 28 06:20:05 EDT 2007
When installing FDO Components i use the ./build_thirdparty.sh comand, and
it returns few warning the fisrt one is Underquoted definition of FDO_SUBST
and then following others underquoted definition FDO_....
am i expected to do something??
By the way it's the second time i try to install MGOS on Fedora, the first
time i wasn't abble to run mgserver, and i wasn't able to find a log in
directory and a message on screen, is there a place to look for informations
in the linux system logs elsewhere ????. This time i install the debug
version i hope i will be able to find more information if it doesn't run.
Thank you for any suggestion
View this message in context: http://www.nabble.com/Mapguide-1.1.0-Linux-Fedora-Core-4-Install-tf3827172s16610.html#a10833960
