[mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Audaire David
DAUDAIRE at ares.fr
Tue May 29 07:59:46 EDT 2007
Well i am now capable to run mgserver i think my last install is the good
one! i think that the main difference is the gcc version 4.0.2. the first
time i made a wrong install of the gcc so ./configure use the 4gcc 4.0.0
version. I am really new to linux and i think the gcc installation was the
most difficult step in the install process.
Audaire David wrote:
> Hi,
> When installing FDO Components i use the ./build_thirdparty.sh comand, and
> it returns few warning the fisrt one is Underquoted definition of
> FDO_SUBST and then following others underquoted definition FDO_....
> am i expected to do something??
> By the way it's the second time i try to install MGOS on Fedora, the first
> time i wasn't abble to run mgserver, and i wasn't able to find a log in
> directory and a message on screen, is there a place to look for
> informations in the linux system logs elsewhere ????. This time i install
> the debug version i hope i will be able to find more information if it
> doesn't run.
> Thank you for any suggestion
View this message in context: http://www.nabble.com/Mapguide-1.1.0-Linux-Fedora-Core-4-Install-tf3827172s16610.html#a10852636
