[mapguide-users] RE: MySQL Database Feature Source Cordiante System
Dhirendra Kumar
dhirendra.mgos at gmail.com
Tue May 29 00:30:05 EDT 2007
Hi Dave,
You are right, not any fied in autodesk studio 2007 for mention cordinate
system but when i am creating layer using data source, then why Layer is not
showing in map preview window of Autodesk studio 2007. Please help me
....... Thankyou in Advance.
Regards,
Dhirendra Kumar
Dave Wilson-3 wrote:
> As per my previous email unless you have the new MGOS beta there is no
> field to specify a coordinate system override since currently MySQL
> doesn't support coordinate systems in the native schema. You can specify
> the correct coordinate system in your map but you will have to zoom and
> find the data to set the extent yourself.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Monday, May 28, 2007 5:07 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MySQL Database Feature Source Cordiante System
> Hi All,
> I have successfully established connection of MySQL 5.0 Database and
> mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but when
> creating Layer using this data source then layer is not showing in
> autodesk
> Layer Preview window, I think this is happning due to cordinate system,
> If i
> am right then where is option of providing cordinate system of MySQL
> data
> source ? If i am wrong then please give me idea, How to solve this
> problem ?
> Regards,
> Dhirendra Kumar
> http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
> 827380s16610.html#a10834515
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3827380s16610.html#a10847820
