[mapguide-users] RE: MySQL Database Feature Source Cordiante System
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue May 29 02:56:08 EDT 2007
As Dave wrote, you must zoom in to the data.
Since you cannot enter coordinates on the layer preview, it will not show.
To view data you must:
Create a datasource.
Create a layer with the datasource.
Create a map.
Select the coordinate system.
Specify the center coordinate manually.
Add the layer.
Press refresh.
If it still won't show, doublecheck the connection on the datasource,
and press the "Test connection" button.
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar wrote:
> Hi Dave,
> You are right, not any fied in autodesk studio 2007 for mention cordinate
> system but when i am creating layer using data source, then why Layer is not
> showing in map preview window of Autodesk studio 2007. Please help me
> ....... Thankyou in Advance.
> Regards,
> Dhirendra Kumar
> Dave Wilson-3 wrote:
>> As per my previous email unless you have the new MGOS beta there is no
>> field to specify a coordinate system override since currently MySQL
>> doesn't support coordinate systems in the native schema. You can specify
>> the correct coordinate system in your map but you will have to zoom and
>> find the data to set the extent yourself.
>> Regards,
>> Dave
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
>> Kumar
>> Sent: Monday, May 28, 2007 5:07 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] MySQL Database Feature Source Cordiante System
>> Hi All,
>> I have successfully established connection of MySQL 5.0 Database and
>> mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but when
>> creating Layer using this data source then layer is not showing in
>> autodesk
>> Layer Preview window, I think this is happning due to cordinate system,
>> If i
>> am right then where is option of providing cordinate system of MySQL
>> data
>> source ? If i am wrong then please give me idea, How to solve this
>> problem ?
>> Regards,
>> Dhirendra Kumar
>> View this message in context:
>> http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
>> 827380s16610.html#a10834515
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070529/ecad5a0e/attachment.html
