[mapguide-users] Need Help
Arq. Luis E. Marin M.
luismarin at simbiosisgroup.net
Tue May 29 08:11:36 EDT 2007
Hi Hidekazu
Thanks for the advice, in your e-mail you wrote "To create polygons without programming, you have to use Autodesk Map 3D.
You can save drawn polygons on your database." But in Map3D I can draw polygons and I can saved in sdf or shp but how I save it in database format?? I can't do that. Many thanks and appreciate your help.
Regards
Luis
CEO
Simbiosis Group Inc.
+58-2129432453 CCS
+58-4165207873 CCS
+01-3109283934 USA
*****REGULACIÓN DE USO DEL CORREO ELECTRÓNICO DE Simbiosis Group Inc. HACIA INTERNET*****
La información contenida en este correo electrónico y cualquier anexo puede ser de carácter confidencial y es propiedad de Simbiosis Group Inc. Sólo está permitido su uso, copia, transmisión, recepción o distribución a personas debidamente autorizadas. Si usted recibió este correo por error por favor destrúyalo y/o elimine cualquier copia guardada en su sistema y notifique inmediatamente al remitente o a la dirección de correo electrónica info at simbiosisgroup.net. Usted no debe utilizar la información contenida para ningún propósito ni compartirla con otras personas.
This e-mail, including any attached files, may contain confidential and privileged information for the sole use of the Simbiosis Group Inc. Any review, use, distribution, or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive information for the intended recipient), please contact the sender by reply info at simbiosisgroup.net and delete all copies of this message.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Hidekazu Shimaji
Sent: Monday, May 28, 2007 7:30 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Need Help
What kind of fdo provider do you use?
An ODBC provider supports only points.
If you use any other providers, I think you can use polygons.
(See fdo documents for detail. Some of them support only 2D polygons.)
To craete polygons without programing, you have to use Autodesk Map 3D.
Regards,
Hidekazu
--- "Arq. Luis E. Marin M." <luismarin at simbiosisgroup.net> wrote:
> I need help to create a polygons from data base because when I connect my
> database and assign the geometry property into correct fields I only
> receive, a few points only, on the layer created based on this database, and
> I need create polygons based on points x,y,z from database not just the
> point I need the polygon conformed for the consecutives points. Sorry about
> my bad English and I hope you can help me guys!
> Regards
> maxx
> CEO
> +58-2129432453? CCS
> +58-4165207873 CCS
> +01-3109283934? USA
> *****REGULACI?キDE USO DEL CORREO ELECTR??CO DE Simbiosis Group Inc. HACIA
> INTERNET*****
> La informaci?? contenida en este correo electr??ico y cualquier anexo puede
> ser de car??ter confidencial y es propiedad de Simbiosis Group Inc. S??o
> est?permitido su uso, copia, transmisi??, recepci?? o distribuci?? a
> personas debidamente autorizadas. Si usted recibi??este correo por error por
> favor destr?alo y/o elimine cualquier copia guardada en su sistema y
> notifique inmediatamente al remitente o a la direcci?? de correo electr??ica
> info at simbiosisgroup.net. Usted no debe utilizar la informaci?? contenida
> para ning? prop??ito ni compartirla con otras personas.
> privileged information for the sole use of the Simbiosis Group Inc.? Any
> review, use, distribution, or disclosure by others is strictly prohibited.?
> ?info at simbiosisgroup.net and delete all copies of this message.
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 5/28/2007
> 11:40 AM
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
No virus found in this incoming message.
Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 5/28/2007 11:40 AM
