[mapguide-users] Need Help
Hidekazu Shimaji hshimaji at ybb.ne.jp
Tue May 29 11:20:45 EDT 2007
Hello,
In a SQLServer provider's case, for example,
you have to create a database (not an instance) with the Map3D.
It is called a "data store".
It contains schemas, feature classes (= tables), and properties (= columns).
After defining a data store, you can connect with it.
While connecting, you can save polygons on it using the Map3D.
To save them, you cannot use a "File" menu but can use
a Map Explorer.
Sorry I cannot explain details because I cannot use the Map3D now.
Please use a help file and check out following keywords:
 spatial database
 data store
 feature class
 FDO (Feature Data Objects)
Regards,
Hidekazu
--- "Arq. Luis E. Marin M." <luismarin at simbiosisgroup.net> wrote:
> Hi Hidekazu
> Thanks for the advice, in your e-mail you wrote "To create polygons without
> programming, you have to use Autodesk Map 3D.
> You can save drawn polygons on your database." But in Map3D I can draw polygons and I
> can saved in sdf or shp but how I save it in database format?? I can't do that. Many
> thanks and appreciate your help.
> Regards
> Luis
> CEO
> Simbiosis Group Inc.
> +58-2129432453  CCS
> +58-4165207873  CCS
> +01-3109283934  USA
> *****REGULACI宵ムN DE USO DEL CORREO ELECTR宵ムNICO DE Simbiosis Group Inc. HACIA
> INTERNET*****
> La informaci将ムn contenida en este correo electr将ムnico y cualquier anexo puede ser de
> car将。cter confidencial y es propiedad de Simbiosis Group Inc. S将ムlo est将。 permitido
> su uso, copia, transmisi将ムn, recepci将ムn o distribuci将ムn a personas debidamente
> autorizadas. Si usted recibi将ム este correo por error por favor destr将窕alo y/o
> elimine cualquier copia guardada en su sistema y notifique inmediatamente al remitente
> o a la direcci将ムn de correo electr将ムnica info at simbiosisgroup.net. Usted no debe
> utilizar la informaci将ムn contenida para ning将穗 prop将ムsito ni compartirla con otras
> personas.
> This e-mail, including any attached files, may contain confidential and privileged
> information for the sole use of the Simbiosis Group Inc.  Any review, use,
> distribution, or disclosure by others is strictly prohibited.  If you are not the
> intended recipient (or authorized to receive information for the intended recipient),
> please contact the sender by reply  info at simbiosisgroup.net and delete all copies of
> this message.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Hidekazu Shimaji
> Sent: Monday, May 28, 2007 7:30 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Need Help
> Hi,
> What kind of fdo provider do you use?
> An ODBC provider supports only points.
> If you use any other providers, I think you can use polygons.
> (See fdo documents for detail. Some of them support only 2D polygons.)
> To craete polygons without programing, you have to use Autodesk Map 3D.
> Regards,
> Hidekazu
> > I need help to create a polygons from data base because when I connect my
> > database and assign the geometry property into correct fields I only
> > receive, a few points only, on the layer created based on this database, and
> > I need create polygons based on points x,y,z from database not just the
> > point I need the polygon conformed for the consecutives points. Sorry about
> > my bad English and I hope you can help me guys!
> > Regards
> > maxx
> > CEO
> > +58-2129432453? CCS
> > +58-4165207873  CCS
> > +01-3109283934? USA
> > *****REGULACI?執DE USO DEL CORREO ELECTR??CO DE Simbiosis Group Inc. HACIA
> > INTERNET*****
> > La informaci?? contenida en este correo electr??ico y cualquier anexo puede
> > ser de car??ter confidencial y es propiedad de Simbiosis Group Inc. S??o
> > est?permitido su uso, copia, transmisi??, recepci?? o distribuci?? a
> > personas debidamente autorizadas. Si usted recibi??este correo por error por
> > favor destr?alo y/o elimine cualquier copia guardada en su sistema y
> > notifique inmediatamente al remitente o a la direcci?? de correo electr??ica
> > info at simbiosisgroup.net. Usted no debe utilizar la informaci?? contenida
> > para ning? prop??ito ni compartirla con otras personas.
> > privileged information for the sole use of the Simbiosis Group Inc.? Any
> > review, use, distribution, or disclosure by others is strictly prohibited.?
> > If you are not the intended recipient (or authorized to receive information
> > for the intended recipient), please contact the sender by reply
> > ?info at simbiosisgroup.net and delete all copies of this message.
> > No virus found in this outgoing message.
> > Checked by AVG Free Edition.
> > Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 5/28/2007
> > 11:40 AM
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> No virus found in this incoming message.
> Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 5/28/2007 11:40 AM
