[mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Chris Gountanis
cgountanis at mpower-tech.com
Wed May 30 09:57:16 EDT 2007
Try using CentOS 4.X which is really just Redhat Enterprise (RHEL). That
seems to be the supported and the easiest method. In my honest opinion using
Fedora Core 4 is bad since it is not being updated anymore.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Audaire David
Sent: Monday, May 28, 2007 5:20 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
When installing FDO Components i use the ./build_thirdparty.sh comand, and
it returns few warning the fisrt one is Underquoted definition of FDO_SUBST
and then following others underquoted definition FDO_....
am i expected to do something??
By the way it's the second time i try to install MGOS on Fedora, the first
time i wasn't abble to run mgserver, and i wasn't able to find a log in
directory and a message on screen, is there a place to look for informations
in the linux system logs elsewhere ????. This time i install the debug
version i hope i will be able to find more information if it doesn't run.
Thank you for any suggestion
View this message in context:
http://www.nabble.com/Mapguide-1.1.0-Linux-Fedora-Core-4-Install-tf3827172s1
6610.html#a10833960
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
