[mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Audaire David
DAUDAIRE at ares.fr
Thu May 31 05:25:52 EDT 2007
Hi
Thank you for the information i keep it in mind for the production
installation.
Now my mgos server is running i have built it in debug mode, i am very
surprised because my windows mgos is really faster than my fedora mgos. does
the release mode accelerate significantly mgos server?
does anybody noticed the fact that windows is faster??
thank's
Audaire David wrote:
> Well i am now capable to run mgserver i think my last install is the good
> one! i think that the main difference is the gcc version 4.0.2. the first
> time i made a wrong install of the gcc so ./configure use the 4gcc 4.0.0
> version. I am really new to linux and i think the gcc installation was the
> most difficult step in the install process.
>> Hi,
>> When installing FDO Components i use the ./build_thirdparty.sh comand,
>> and it returns few warning the fisrt one is Underquoted definition of
>> FDO_SUBST and then following others underquoted definition FDO_....
>> am i expected to do something??
>> By the way it's the second time i try to install MGOS on Fedora, the
>> first time i wasn't abble to run mgserver, and i wasn't able to find a
>> log in directory and a message on screen, is there a place to look for
>> informations in the linux system logs elsewhere ????. This time i install
>> the debug version i hope i will be able to find more information if it
>> doesn't run.
>> Thank you for any suggestion
View this message in context: http://www.nabble.com/Mapguide-1.1.0-Linux-Fedora-Core-4-Install-tf3827172s16610.html#a10890408
