[mapguide-users] Newbie: Tutorial on setting up the server
Ryan Northcott
rnorthcott at gmail.com
Fri Nov 2 09:49:04 EDT 2007
I believe there is a web-based version, but it is not as user friendly. And
I think the last step of creating a layout is not implemented, you have to
do that manually.
In your Mapguide web site directory check out the folder called webstudio:
http://localhost/mapguide/webstudio
I know there is a tutorial for the Studio Application that it comes with
when you install that walks you through creating a simple map and getting it
online.
-Ryan
On 11/2/07, gingerbbm <stuart.jones at jacobs.com> wrote:
> I guess I'll give Autodesk MapGuide Studio a try then.
> Is the configuration too hairy to do manually though? I'd still like to
> see
> it described in a step-by-step guide. What did people do before MapGuide
> Studio came along?!
> http://www.nabble.com/Newbie%3A-Tutorial-on-setting-up-the-server-tf4734877s16610.html#a13547596
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071102/77738807/attachment.html
