[mapguide-users] Error.log of MapGuide Enterprise
Eric123 erictsn at cadbeyond.com
Sat Nov 3 07:44:40 EDT 2007
Hi All.
I just installed the MGE2008 to Fedora Core 4. Actually I try to use
MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
generated. OK I check with the error.log. I got the following warning.
Anyone know how to fix? Do I need to re-install/compile FDO?
Thanks in advance.
Eric>-(
<2007-11-01T16:49:15>                   Administrator
 Error: An exception occurred in FDO component.
        CLNT_12_FILE_NOT_EXISTS
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute line 116 file
OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties line 1581 file
ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
  - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp  An
<2007-11-01T16:49:16>                   Administrator
 Error: Failed to stylize layer: CityLimits
 StackTrace:
  - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
View this message in context: http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
