[mapguide-users] MGE, Base layers and consistent scale ranges
ori gudes ori at sinapistech.com
Sun Nov 4 09:03:38 EST 2007
Dear Maksim
can you send me a sample that make it more clear ?
Ori
Maksim Sestic wrote:
> You should export map .xml definition file, correct scales by hand, then
> re-import changed .xml file to the MG server using web tier test
> application. I guess there's a change request for MG Studio regarding this
> one.
> Regards,
> Maksim Sestic
> ori gudes wrote:
>> Dear Maksim
>> Do you have any information about generating consistent set of scales?
>> Cheers Ori
>> Do you have any information of
>>> Dear all,
>>> I'm using MGE 2008 with MapGuide Studio 2008, and I'm new to Base Layers
>>> concept.
>>> I created one Base Layer with a raster Layer in it. Then I set the
>>> nearest Zoom In (250), farthest Zoom Out (50000) and total number of
>>> scales (10) parameters. End result is autogenerated set of scales. When
>>> I run this map in Web browser I can zoom only to scales matching the
>>> ones in BaseLayer's autogenerated scale list.
>>> The question is - how do I change single scale in (auto)generated scale
>>> list? I.e. I want to have consistent, geodetic set of scales as in 100,
>>> 250, 500, 1000, 1500, 2000, 2500, ... 50000. Is it doable with MGS at
>>> all?
>>> With kindest regards,
>>> Maksim Sestic
View this message in context: http://www.nabble.com/MGE%2C-Base-layers-and-consistent-scale-ranges-tf4520911s16610.html#a13573215
