[mapguide-users] MGE, Base layers and consistent scale ranges
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sun Nov 4 12:42:12 EST 2007
After saving the layer in MapGuide Studio, select the menu "File" and
"Save as xml..."
The file it saves is the internal representation of the MapDefinition.
You can open this file with almost any text editor (plain text only, no
MS Word).
You can use notepad if you like.
Somewhere in the file will be a an xml entry called <FiniteScales>.
In this entry you can hand modify the scales.
After you are done, you can reinsert the MapDefintion into the MapGuide
server.
Open a browser with:
http://localhost/mapguide/mapagent/index.html
Select "Resource", the "SetResource"
To the right, enter the resourceID you want to save the map under.
Browse the file as the "Content" item.
Leave the "Header" blank.
Press submit.
You will now have updated/create a MapDefintion in the server.
Regards, Kenneth, GEOGRAF A/S
ori gudes skrev:
> Dear Maksim
> can you send me a sample that make it more clear ?
> Ori
> Maksim Sestic wrote:
>> You should export map .xml definition file, correct scales by hand, then
>> re-import changed .xml file to the MG server using web tier test
>> application. I guess there's a change request for MG Studio regarding this
>> one.
>> Regards,
>> Maksim Sestic
>> ori gudes wrote:
>>> Dear Maksim
>>> Do you have any information about generating consistent set of scales?
>>> Cheers Ori
>>> Do you have any information of
>>>> Dear all,
>>>> I'm using MGE 2008 with MapGuide Studio 2008, and I'm new to Base Layers
>>>> concept.
>>>> I created one Base Layer with a raster Layer in it. Then I set the
>>>> nearest Zoom In (250), farthest Zoom Out (50000) and total number of
>>>> scales (10) parameters. End result is autogenerated set of scales. When
>>>> I run this map in Web browser I can zoom only to scales matching the
>>>> ones in BaseLayer's autogenerated scale list.
>>>> The question is - how do I change single scale in (auto)generated scale
>>>> list? I.e. I want to have consistent, geodetic set of scales as in 100,
>>>> 250, 500, 1000, 1500, 2000, 2500, ... 50000. Is it doable with MGS at
>>>> all?
>>>> With kindest regards,
>>>> Maksim Sestic
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071104/73ecd625/attachment.html
