[mapguide-users] Error.log of MapGuide Enterprise
Eric123 erictsn at cadbeyond.com
Sun Nov 4 10:47:29 EST 2007
The MGE 2008 will also be installed the FDO 3.2.2 when to install the
MapGuide server.
Jack Lee-3 wrote:
> Hi,
> I am not familiar with the MGE2008 install. Does it come with a separate
> FDO install?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric123
> Sent: Saturday, November 03, 2007 9:40 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Error.log of MapGuide Enterprise
> Hi Jack,
> Thanks.
> But under the fdo-3.2.2 directory, I cannot find the providers.xml file!
> [root at localhost lib]# ls
> com                           libSchemaMgr_OV.la
> FdoATILConfiguration.xml      libSchemaMgr_OVOR.so
> libArcSDEProvider-3.2.2.so    libSchemaMgr_OV.so
> libArcSDEProvider91-3.2.2.so  libSDFProvider-3.2.2.so
> libArcSDEProvider91.la        libSDFProvider.la
> libArcSDEProvider91.so        libSDFProvider.so
> libArcSDEProvider92-3.2.2.so  libSHPOverrides-3.2.2.so
> libArcSDEProvider92.la        libSHPOverrides.la
> libArcSDEProvider92.so        libSHPOverrides.so
> libArcSDEProvider.la          libSHPProvider-3.2.2.so
> libArcSDEProvider.so          libSHPProvider.la
> libFDO-3.2.2.so               libSHPProvider.so
> libFdoATILSession.so          libUserMgr-3.2.2.so
> libFDO.la                     libUserMgr.la
> libFdoMySQL-3.2.2.so          libUserMgr.so
> libFdoMySQL.la                libWFSProvider-3.2.2.so
> libFdoMySQL.so                libWFSProvider.la
> libFdoODBC-3.2.2.so           libWFSProvider.so
> libFdoODBC.la                 libWMSOverrides-3.2.2.so
> libFdoODBC.so                 libWMSOverrides.la
> libFdoOws-3.2.2.so            libWMSOverrides.so
> libFdoOws.la                  libWMSProvider-3.2.2.so
> libFdoOws.so                  libWMSProvider.la
> libFdoRdbms.so                libWMSProvider.so
> libFDO.so                     libxalan-c.so
> libgdal.so                    libxalanMsg.so
> libgdal.so.1                  libxalanMsg.so.17
> libgdal.so.1.9.0              libxalanMsg.so.17.0
> libRFPOverrides.so            libxerces-c.so
> libRFPProvider.so             libxerces-c.so.25
> libSchemaMgr_OV-3.2.2.so      libxerces-c.so.25.0
> Eric
> Jack Lee-3 wrote:
>> Hi,
>> I am not sure which FDO version you are using but providers.xml would be
>> under a directory like:
>> /usr/local/fdo-3.2.2/lib.
>> ________________________________________
>> [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth, GEOGRAF
>> A/S
>> [ks at geograf.dk]
>> Sent: Saturday, November 03, 2007 1:15 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Error.log of MapGuide Enterprise
>> It should be located in server/bin/fdo, along with at least SDFProvider.o
>> and SHPProvider.o.
>> I'm unfamilliar with the Linux install package, but you need the FDO
>> Providers, if they are not included in the package.
>> Regards, Kenneth, GEOGRAF A/S
>> Eric123 skrev:
>> Thanks Jack.
>> I try to locate "providers.xml". Nothing can find. What is the exact
>> directory for the file?
>> Eric
>> Jack Lee-3 wrote:
>> Hi,
>> Does the file providers.xml exist?
>> From:
>> mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>
>> Sent: Saturday, November 03, 2007 7:45 AM
>> To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
>> Subject: [mapguide-users] Error.log of MapGuide Enterprise
>> Hi All.
>> I just installed the MGE2008 to Fedora Core 4. Actually I try to use
>> MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
>> generated. OK I check with the error.log. I got the following warning.
>> Anyone know how to fix? Do I need to re-install/compile FDO?
>> Thanks in advance.
>> Eric>-(
>> <2007-11-01T16:49:15>                   Administrator
>>  Error: An exception occurred in FDO component.
>>         CLNT_12_FILE_NOT_EXISTS
>>  StackTrace:
>>   - MgFeatureServiceHandler.ProcessOperation line 83 file
>> FeatureServiceHandler.cpp
>>   - MgOpGetIdentityProperties.Execute line 116 file
>> OpGetIdentityProperties.cpp
>>   - MgServerDescribeSchema.GetIdentityProperties line 1581 file
>> ServerDescribeSchema.cpp
>>   - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
>>   - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp
>> An
>> <2007-11-01T16:49:16>                   Administrator
>>  Error: Failed to stylize layer: CityLimits
>>  StackTrace:
>>   - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
>> View this message in context:
>> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13569196
View this message in context: http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13574539
