[mapguide-users] Error.log of MapGuide Enterprise
Bruce Dechant
bruce.dechant at autodesk.com
Tue Nov 6 12:46:15 EST 2007
MGE 2008 installer should have installed the FDO providers.xml file.
Did you try reinstalling the MGE 2008 server?
Here is a copy of what the providers.xml file should look like.
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<FeatureProviderRegistry>
<FeatureProvider>
<Name>OSGeo.ArcSDE.3.2</Name>
<DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>
<Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server.</Description>
<IsManaged>False</IsManaged>
<Version>3.2.2.0</Version>
<FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libArcSDEProvider.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.MySQL.3.2</Name>
<DisplayName>OSGeo FDO Provider for MySQL</DisplayName>
<Description>Read/write access to MySQL-based data store. Supports spatial data types and spatial query operations.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoMySQL.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.ODBC.3.2</Name>
<DisplayName>OSGeo FDO Provider for ODBC</DisplayName>
<Description>Read/write access to ODBC-based data store. Supports XYZ point features.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoODBC.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>Autodesk.Oracle.3.2</Name>
<DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
<Description>Read/write access to feature data in an Oracle-based data store. Supports spatial indexing, long transactions, and persistent locking.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>Autodesk.Raster.3.2</Name>
<DisplayName>Autodesk FDO Provider for Raster</DisplayName>
<Description>Read access to various raster-based file formats. Supports georeferenced file-based raster images, DEM files and 3D grid surfaces.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libRFPProvider.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.SHP.3.2</Name>
<DisplayName>OSGeo FDO Provider for SHP</DisplayName>
<Description>Read/write access to spatial and attribute data in an ESRI SHP file.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libSHPProvider.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.SDF.3.2</Name>
<DisplayName>OSGeo FDO Provider for SDF</DisplayName>
<Description>Read/write access to Autodesk's spatial database format, a file-based personal geodatabase that supports multiple features/attributes, spatial indexing, and file-locking.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libSDFProvider.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.WFS.3.2</Name>
<DisplayName>OSGeo FDO Provider for WFS</DisplayName>
<Description>Read access to OGC WFS-based data store.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libWFSProvider.so</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.WMS.3.2</Name>
<DisplayName>OSGeo FDO Provider for WMS</DisplayName>
<Description>Read access to OGC WMS-based data store.</Description>
<LibraryPath>/usr/local/fdo-3.2.2/lib/libWMSProvider.so</LibraryPath>
</FeatureProvider>
</FeatureProviderRegistry>
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric123
Sent: November 4, 2007 8:47 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Error.log of MapGuide Enterprise
The MGE 2008 will also be installed the FDO 3.2.2 when to install the
MapGuide server.
Jack Lee-3 wrote:
> Hi,
> I am not familiar with the MGE2008 install. Does it come with a separate
> FDO install?
> Sent: Saturday, November 03, 2007 9:40 PM
> Hi Jack,
> Thanks.
> But under the fdo-3.2.2 directory, I cannot find the providers.xml file!
> [root at localhost lib]# ls
> com libSchemaMgr_OV.la
> FdoATILConfiguration.xml libSchemaMgr_OVOR.so
> libArcSDEProvider-3.2.2.so libSchemaMgr_OV.so
> libArcSDEProvider91-3.2.2.so libSDFProvider-3.2.2.so
> libArcSDEProvider91.la libSDFProvider.la
> libArcSDEProvider91.so libSDFProvider.so
> libArcSDEProvider92-3.2.2.so libSHPOverrides-3.2.2.so
> libArcSDEProvider92.la libSHPOverrides.la
> libArcSDEProvider92.so libSHPOverrides.so
> libArcSDEProvider.la libSHPProvider-3.2.2.so
> libArcSDEProvider.so libSHPProvider.la
> libFDO-3.2.2.so libSHPProvider.so
> libFdoATILSession.so libUserMgr-3.2.2.so
> libFDO.la libUserMgr.la
> libFdoMySQL-3.2.2.so libUserMgr.so
> libFdoMySQL.la libWFSProvider-3.2.2.so
> libFdoMySQL.so libWFSProvider.la
> libFdoODBC-3.2.2.so libWFSProvider.so
> libFdoODBC.la libWMSOverrides-3.2.2.so
> libFdoODBC.so libWMSOverrides.la
> libFdoOws-3.2.2.so libWMSOverrides.so
> libFdoOws.la libWMSProvider-3.2.2.so
> libFdoOws.so libWMSProvider.la
> libFdoRdbms.so libWMSProvider.so
> libFDO.so libxalan-c.so
> libgdal.so libxalanMsg.so
> libgdal.so.1 libxalanMsg.so.17
> libgdal.so.1.9.0 libxalanMsg.so.17.0
> libRFPOverrides.so libxerces-c.so
> libRFPProvider.so libxerces-c.so.25
> libSchemaMgr_OV-3.2.2.so libxerces-c.so.25.0
> Eric
> Jack Lee-3 wrote:
>> Hi,
>> I am not sure which FDO version you are using but providers.xml would be
>> under a directory like:
>> /usr/local/fdo-3.2.2/lib.
>> ________________________________________
>> [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth, GEOGRAF
>> A/S
>> [ks at geograf.dk]
>> Sent: Saturday, November 03, 2007 1:15 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Error.log of MapGuide Enterprise
>> It should be located in server/bin/fdo, along with at least SDFProvider.o
>> and SHPProvider.o.
>> I'm unfamilliar with the Linux install package, but you need the FDO
>> Providers, if they are not included in the package.
>> Regards, Kenneth, GEOGRAF A/S
>> Eric123 skrev:
>> Thanks Jack.
>> I try to locate "providers.xml". Nothing can find. What is the exact
>> directory for the file?
>> Eric
>> Jack Lee-3 wrote:
>> Hi,
>> Does the file providers.xml exist?
>> From:
>> mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>
>> Sent: Saturday, November 03, 2007 7:45 AM
>> To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
>> Subject: [mapguide-users] Error.log of MapGuide Enterprise
>> Hi All.
>> I just installed the MGE2008 to Fedora Core 4. Actually I try to use
>> MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
>> generated. OK I check with the error.log. I got the following warning.
>> Anyone know how to fix? Do I need to re-install/compile FDO?
>> Thanks in advance.
>> Eric>-(
>> <2007-11-01T16:49:15> Administrator
>> Error: An exception occurred in FDO component.
>> CLNT_12_FILE_NOT_EXISTS
>> StackTrace:
>> - MgFeatureServiceHandler.ProcessOperation line 83 file
>> FeatureServiceHandler.cpp
>> - MgOpGetIdentityProperties.Execute line 116 file
>> OpGetIdentityProperties.cpp
>> - MgServerDescribeSchema.GetIdentityProperties line 1581 file
>> ServerDescribeSchema.cpp
>> - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
>> - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp
>> An
>> <2007-11-01T16:49:16> Administrator
>> Error: Failed to stylize layer: CityLimits
>> StackTrace:
>> - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
>> View this message in context:
>> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13569196
View this message in context: http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13574539
