[mapguide-users] add push pin marker on search results (hit on search results)
Maciej Skorczewski maciej.skorczewski at procad.pl
Mon Nov 5 02:49:09 EST 2007
ok!
i found solution...just change
from
$ll84Wkt = 'GEOGCS["LL84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",1]]';
to
$ll84Wkt =
'GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]';
it's work fine :)
Maciej Skorczewski pisze:
> Hi!
> in MapGuide Sample Aplication
> http://data.mapguide.com/mapguide/phpviewersample/ajaxviewersample.php
> was a functionality , place push pin marker on search results(parcels).
> After move my aplication to MG 1.2 i can't see this pushpins...mg don't
> give error any message...
> did anybody solve this problem?
Maciej Skórczewski
