[mapguide-users] add push pin marker on search results (hit on
search results)
Nimrod Cnaan
nimcnaan at hotmail.com
Tue Nov 6 12:54:08 EST 2007
Thanks
you are the manNimrod CnaanSenior GIS Dev
> Date: Mon, 5 Nov 2007 08:49:09 +0100> From: maciej.skorczewski at procad.pl> To: mapguide-users at lists.osgeo.org> Subject: Re: [mapguide-users] add push pin marker on search results (hit on search results)> > ok!> > i found solution...just change> > from> > $ll84Wkt = 'GEOGCS["LL84",DATUM["WGS_1984",SPHEROID["WGS > 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",1]]';> > to> $ll84Wkt = > 'GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]';> > > it's work fine :)> > > Maciej Skorczewski pisze:> > Hi!> > > > in MapGuide Sample Aplication> > http://data.mapguide.com/mapguide/phpviewersample/ajaxviewersample.php> > > > was a functionality , place push pin marker on search results(parcels).> > > > After move my aplication to MG 1.2 i can't see this pushpins...mg don't > > give error any message...> > > > did anybody solve this problem?> > > -- > > > Maciej Skórczewski> _______________________________________________> mapguide-users mailing list> mapguide-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071106/97c583fc/attachment.html
