[mapguide-users] Security on layers or featureSource
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Nov 7 06:41:36 EST 2007
I can see why this could be usefull, but I can see situations where it
would be troublesome to detect why a layer won't render.
If you haven't already done it, you can create a ticket on Trac and
request it as an enhancement.
http://trac.osgeo.org/mapguide/
Regards, Kenneth, GEOGRAF A/S
Bruno Scott skrev:
> Actually when we set a no access permission on a layer definition for a given
> user
> and we open the map referencing this layer (using the same user ) we got
> this message :
> Permission denied to resource:
> Library://Samples/Sheboygan/Layers/Districts.LayerDefinition
> Library://Samples/Sheboygan/Layers/Districts.LayerDefinition Exception
> occured in method MgResourceHeaderManager.CheckPermission at line 2497 in
> file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceHeaderManager.cpp
> I know that is the intended behavior
> But it would be great if the mapgudie server remove the layers with no
> access on the fly.
> This would gives Administrator a very high level of flexibility on
> controling the security.
> Just by setting security permissions on some layers or featureSource we
> could control
> what a specific user can see in any map
> Bruno
