[mapguide-users] XP crashes mapgude service
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Nov 7 08:56:30 EST 2007
I'm not sure what you mean by "xp is not supported", I have many
machines with MapGuide Open Source on Windows XP, some with IIS+.Net and
some with Apache+PHP.
Did you contact Autodesk, as you are running the Enterprise edition?
Did you change permissions on any files or the service?
It would appear that it fails to read the config file.
Regards, Kenneth, GEOGRAF A/S
(G) Sergio Libman skrev:
> I know that xp is not supported but we are making some tests to make
> demos over xp OS in a notebook locally.
> When I install the services Apache and MapGuide Enterprise2008 on php,
> it runs but when attempt to restart the service MapGide Enterprise2008
> generate a windows error and stops inmediatly.
> If I try to start from cmd line this is the error:
> /C:\Program
> Files\Autodesk\MapGuideEnterprise2008\Server\Bin>mgserver2008.exe /in/
> /teractive/
> /Running the server interactively as an application instead of as a
> service./
> /(5944|5948) An unclassified exception occurred./
> /Exception occurred in method MgServer.open at line 1059 in file
> c:\build_bond_area\bond_nightly\build_41.3\ent\os\server\src\core\Server.cpp/
> /Exception occurred in method MgLogManager.QueueLogEntry at line 1930
> in file c:\/
> /build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\LogManager.cpp/
> /This application has requested the Runtime to terminate it in an
> unusual way./
> /Please contact the application's support team for more information./
> Anyone could help me on this?
> Sergio
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071107/97fa96d4/attachment.html
