[mapguide-users] Base Layers - Raster
Andy Morsell
amorsell at spatialgis.com
Thu Nov 8 13:14:55 EST 2007
It looks like there are inconsistent issues with raster images in base
layers. I will try to test later today on my client's machine where we had
the first problem to see if the issue still exists with 1.2. I just tried
on another 1.2 machine with one single larger (250 MB) SID and it seemed to
work okay creating the tile images. One thing to watch out for: if you have
your map image request set to JPG in your ajaxmappane.templ for performance
reasons, than it will be opaque on top of your base layers. You will have
to switch it back to PNG in order for the overlay transparency to work and
to see your base layers.
Andy
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Thursday, November 08, 2007 9:52 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Base Layers - Raster
Ok, Thanks. It sounds like that thread and you are saying that base layers
do not work with raster images?
but I would think it does work if Kori spent the time to create the
FMTilingEngine.
Can you let me know where I can find Jason's tile indexing?
Thanks for the help, I have spent way too much time on this.
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, November 08, 2007 12:39 PM
To: 'MapGuide Users Mail List'
I'm not sure that this problem was ever fixed. I had the same issue with
using ECW images as part of a base layer and eventually gave up. With other
GDAL improvements (including Jason's tile indexing), I was able to get
reasonable performance out of standard raster layers, so I have not
revisited this issue recently.
See this Trac ticket for more information:
http://trac.osgeo.org/mapguide/ticket/187
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
Sent: Thursday, November 08, 2007 8:26 AM
As a follow up, it seems as though it is not creating the tiles correctly in
Mapguide.When I look in the cache most of the files are 2kb and blank
images.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
_____
Sent: Thursday, November 08, 2007 10:21 AM
Subject: [mapguide-users] Base Layers - Raster
I am having some serious issues using MrSID files as Base Layers.The images
display fine as regular layers but the client ALWAYS locks up when I have
them as base layers and I definitely want to use this feature for
performance reasons. Anyone have anything I can try?
This is the case whether I pre-populate the cache or not.
Brian Berdel
Systems Administrator/Programmer Analyst
425 Commerce Drive, Suite 200
Fort Washington, Pennsylvania 19034
p: 215.283.9444
f: 215.283.9858
brian.berdel at mcmtrans.com
<http://www.mcmtrans.com>
New England | Mid-Atlantic | Florida
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071108/9702b0b9/attachment.html
