[mapguide-users] Adding marker on the fly with tooltip
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Nov 12 03:01:51 EST 2007
What I mean is that the xml fragment you specified does not constitute a
layer definition document.
Therefore there must be some kind of "outer" xml document that that fragment
would have be merged with to form a valid layer definition document.
Looking at the php code (and I'm just grabbing thin air here). I'm guessing
$factory->CreateLayerDefinition() is where the outer xml document comes
from. So take a look at that function, as that is probably where you insert
your tooltip tag.
- Jackie
Kencana wrote:
> Hi Jacky,
> Thanks for the reply.
> I don't quite understand what you mean by outer xml. anyway, this is what
> i did for drawing the marker. also I have attached 1 layer definition
> file, templ file, and also the layerdefinition.php file (the file consists
> the function in drawing the marker based on the xml file). I hope you can
> help me out. And I am really appreciate that.
> Thank you
> Regards,
> Kencana Kesuma
> $factory = new LayerDefinitionFactory();
> // Create a mark symbol
> $resourceId = 'Library://Migrated Files/Stars.SymbolLibrary';
> $symbolName = 'Red';
> $testing = 'Test 123';
> $width = '25'; // points
> $height = '25'; // points
> $color = 'FFFF0000';
> $markSymbol = $factory->CreateMarkSymbol($resourceId, $symbolName,
> $width, $height, $color);
> // Create a text symbol
> $text = "ID";
> $fontHeight="12";
> $foregroundColor = 'FF000000';
> $textSymbol = $factory->CreateTextSymbol($text,
> $fontHeight, $foregroundColor);
> // Create a point rule.
> $legendLabel = 'trees';
> $filter = '';
> $pointRule = $factory->CreatePointRule($legendLabel,
> $filter, $textSymbol, $markSymbol);
> // Create a point type style.
> $pointTypeStyle = $factory->
> CreatepointTypeStyle($pointRule);
> // Create a scale range.
> $minScale = '0';
> $maxScale = '1000000000000';
> $pointScaleRange = $factory->CreateScaleRange($minScale,
> $maxScale, $pointTypeStyle);
> $featureName = 'PointSchema:Points';
> $geometry = 'GEOM';
> $layerDefinition = $factory->
> CreateLayerDefinition($featureSourceName, $featureName,
> $geometry, $pointScaleRange);
> // Add the layer to the map
> $newLayer = add_layer_definition_to_map($layerDefinition, "Points",
> "Points of Interest", $sessionId, $resourceService, $map);
> add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
> Jackie Ng wrote:
>> Do you have an "outer" xml template that you are merging this with? If
>> so, that's the one where you'll have to place the <ToolTip> tag under.
>> - Jackie
>> Kencana wrote:
>>> Hi Jacky,
>>> Thank you for the reply.
>>> Anyway I can't find the geometry tag under the marksymbol.templ.
>>> this is what i have in markersymbol.templ
>>> <W2D>
>>> <Unit>Points</Unit>
>>> <SizeContext>DeviceUnits</SizeContext>
>>> <SizeX>%s</SizeX>
>>> <SizeY>%s</SizeY>
>>> <Rotation>0</Rotation>
>>> <MaintainAspect>true</MaintainAspect>
>>> <W2DSymbol>
>>> <ResourceId>%s</ResourceId>
>>> <LibraryItemName>%s</LibraryItemName>
>>> </W2DSymbol>
>>> <FillColor>%s</FillColor>
>>> <LineColor>FF000000</LineColor>
>>> <TextColor>FF000000</TextColor>
>>> <ToolTip>test 123</ToolTip>
>>> </W2D>
>>> I did make some changes to the LayerDefinition-1.0.0.xsd and the error
>>> message has gone. however,
>>> i can't see the tool tip when i mouse over the marker.
>>> any idea of this?
>>> anyway i am still using mapguide opensource 1.1.0.
>>> because the new version (1.2) the marker is not shown on the map.Have
>>> mentioned about this issue in this forum, but so far I havent see any
>>> solution for it yet.
>>> Thank you
>>> Regards,
>>> Kencana
>>> Jackie Ng wrote:
>>>> Did you put the tooltip tag in the right location? The <ToolTip> tag
>>>> usually follows the <Geometry> tag in a layer definition document.
>>>> - Jackie
>>>> Kencana wrote:
>>>>> Hi,
>>>>> Can we modify the markersymbol.templ file to add <ToolTip></ToolTip>
>>>>> tag into it?
>>>>> I have try to add it but it returns me such error message.
>>>>> ERROR: The new XML document is invalid.
>>>>> .PHP Warning: Element W2D content check failure in C:\Program
>>>>> Files\MapGuideOpenSource\WebServerExtensions\www\CAN MAP
>>>>> Files\layer_functions.php on line 27 PHP Fatal error: Call to a member
>>>>> function SetGroup() on a non-object in C:\Program
>>>>> Files\layer_functions.php on line 66
>>>>> any idea on how i can make it work?
>>>>> Thank you
>>>>> Regards,
>>>>> Kencana Kesuma
> http://www.nabble.com/file/p13699701/LayerDefinition-1.0.0.xsd
> http://www.nabble.com/file/p13699701/layerdefinitionfactory1.php
> http://www.nabble.com/file/p13699701/marksymbol.templ marksymbol.templ
View this message in context: http://www.nabble.com/Adding-marker-on-the-fly-with-tooltip-tf4788633s16610.html#a13701421
