[mapguide-users] RenderingService and DPI (How to change DPI
	before	rendering)
    Kenneth, GEOGRAF A/S
    ks at geograf.dk
    Mon Nov 12 14:21:10 EST 2007
I have no used the ColdFusion stuff that you are using, but the call to
GetMapImage does have a DPI parameter, that you can use.
I have no trouble getting the images as I want, although the PDF format
usually reduces quality a bit.
Try looking at the code in the viewer for "Printable Page", as it shows
how to use the calls.
Regards, Kenneth, GEOGRAF A/S
Scott Hameister skrev:
> I can send anyone interested sample PDFs of the same map stream at
> different screen resolutions
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Scott
> Hameister
> *Sent:* Monday, November 12, 2007 12:00 PM
> *To:* 'MapGuide Users Mail List'
> *Subject:* [mapguide-users] RenderingService and DPI (How to change
> DPI before rendering)
> How do I change the DPI that The  Rendering Service Uses when Creating
> a map...
> The Streamed Image from the rendering service is being poured into a
> PDF file...the problem is that the quality of the PDF varies based on
> the Resolution my Screen is at when I render the Stream, instead of
> being consistent in the PDF. If I'm at 1024 x 768 the PDF map is
> grainier than if I'm at 1920x1200 resolution when  I stream the image
> How can I address this to make the PDF quality the same for all users?
> <cfset newMap =
> renderingSrvc.rendermap(map,mgselection,realCenter,Javacast("DOUBLE",SesMapScale),Javacast
> ("INT",SesScrnW),Javacast("INT",SesScrnH),mapcolor,"PNG")>
> Above Is my Coldfusion call...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071112/6039e2f9/attachment.html
