[mapguide-users] RenderingService and DPI (How to change DPI before rendering)
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Nov 12 14:42:20 EST 2007
I see your point.
The runtime map has a DisplayDPI property, but it is readonly.
I also assumed that the API had the same parameters as the actual
service call, but not in this case.
You can use the "SETDATAEXTENT" call to set the DPI, but it does change
current DPI.
You should be able to save a copy of the runtime map though.
Regards, Kenneth, GEOGRAF A/S
Scott Hameister skrev:
> That is true...But that is using an FCGI call and not the Rendering
> Service API...The API has no mention of DPI...I would think the API
> would have all the same capabilities that an FCGI call has?
> I started using the FCGI calls...but it became annoying because
> changing the FCGI DPI...caused the Current maps DPI to change...
> If I created a new Session to call the FCGI on, then my selection XML
> from the original Sessions map didn't work in the New Session, because
> the Layer ID changed...etc.
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Kenneth, GEOGRAF A/S
> *Sent:* Monday, November 12, 2007 1:21 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] RenderingService and DPI (How to
> I have no used the ColdFusion stuff that you are using, but the call
> to GetMapImage does have a DPI parameter, that you can use.
> I have no trouble getting the images as I want, although the PDF
> format usually reduces quality a bit.
> Try looking at the code in the viewer for "Printable Page", as it
> shows how to use the calls.
> I can send anyone interested sample PDFs of the same map stream at
> different screen resolutions
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Scott
> Hameister
> *Sent:* Monday, November 12, 2007 12:00 PM
> *To:* 'MapGuide Users Mail List'
> *Subject:* [mapguide-users] RenderingService and DPI (How to change
> How do I change the DPI that The  Rendering Service Uses when Creating
> a map...
> The Streamed Image from the rendering service is being poured into a
> PDF file...the problem is that the quality of the PDF varies based on
> the Resolution my Screen is at when I render the Stream, instead of
> being consistent in the PDF. If I'm at 1024 x 768 the PDF map is
> grainier than if I'm at 1920x1200 resolution when  I stream the image
> How can I address this to make the PDF quality the same for all users?
> <cfset newMap =
> renderingSrvc.rendermap(map,mgselection,realCenter,Javacast("DOUBLE",SesMapScale),Javacast
> ("INT",SesScrnW),Javacast("INT",SesScrnH),mapcolor,"PNG")>
> Above Is my Coldfusion call...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071112/d5c5f9b7/attachment.html
