[mapguide-users] newbie : What I should do next?
Jason Birch
Jason.Birch at nanaimo.ca
Wed Nov 14 22:45:47 EST 2007
Hello,
Your next step is to set up a website that encapsulates that web layout.
Assuming that you have the MapGuide web extensions on a publicly available website, all you have to do is embed the location of your web layout in an IFRAME with appropriate credentials passed through.
The simplest way of doing this is to grab the php viewer sample from here:
http://mapguide.osgeo.org/download1.2.0.html#samples-1.2.x
and change the appropriate layout to point to your web layout instead of Sheboygan.
Jason
Subject: [mapguide-users] newbie : What I should do next?
I've done these:
1. Install the MapGuide Open Source (server & web extension)
2. Install the 60-day trial of MapGuide Studio
3. Load procedures, web layout and map..
4. view in browser - successfully done
what should i do next to complete this project so that public user can view
my map? what about the load packages? what folder should i make package? is
it the load procedure? i've done make package the load procedure, and
succeeded. i'm using php.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071114/1977cd85/attachment.bin
