[mapguide-users] newbie : What I should do next?
mimie idris
afzaiumi_idris at yahoo.com
Thu Nov 15 03:23:42 EST 2007
Thanks Jason,
yes, i've done as per what you've described. am i load the right package? is
that all i need to do?
JasonBirch wrote:
> Hello,
> Your next step is to set up a website that encapsulates that web layout.
> Assuming that you have the MapGuide web extensions on a publicly available
> website, all you have to do is embed the location of your web layout in an
> IFRAME with appropriate credentials passed through.
> The simplest way of doing this is to grab the php viewer sample from here:
> http://mapguide.osgeo.org/download1.2.0.html#samples-1.2.x
> and change the appropriate layout to point to your web layout instead of
> Sheboygan.
> Jason
> ________________________________
> From: mimie idris
> Subject: [mapguide-users] newbie : What I should do next?
> I've done these:
> 1. Install the MapGuide Open Source (server & web extension)
> 2. Install the 60-day trial of MapGuide Studio
> 3. Load procedures, web layout and map..
> 4. view in browser - successfully done
> what should i do next to complete this project so that public user can
> view
> my map? what about the load packages? what folder should i make package?
> is
> it the load procedure? i've done make package the load procedure, and
> succeeded. i'm using php.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/newbie-%3A-What-I-should-do-next--tf4809367s16610.html#a13763411
