[mapguide-users] physical files
Jason Birch
Jason.Birch at nanaimo.ca
Sat Nov 17 14:34:13 EST 2007
Hmm, that's interesting (about the different standalone php.exe). I don't believe that it has the MapGuide extensions loaded, as all it's doing is interacting with DBXML. You'll want to run this script using the php.exe that's in the main WebServerExtensions/php directory.
You shouldn't need constants.php; the only constant you should need is the ResourceType, which I've hard-coded.
What version of MapGuide are you running? I coded this against 1.2.0. There have been some changes between MapGuide 1.0 and 1.2 so if you are not using 1.2 you may need to use MgSite instead of MgSiteConnection. You may also run into problems with the XML stuff; I'm not sure if it was supported in PHP 5.0 (earlier versions of MapGuide came with this instead of 5.2)
Jason
Subject: Re: [mapguide-users] physical files
nice job... i got stuck trying to run this in C:\Program Files\MapGuideOpenSource\Server\RepositoryAdmin
it's got a different standalone php.exe there
i changed
// Define the path to your webconfig file if it's somewhere else
define("MG_WEB_CONFIG_FILE",'../../WebServerExtensions/www/webconfig.ini');
and got
C:\Program Files\MapGuideOpenSource\Server\RepositoryAdmin>PHP cli_listfiles.php Admin
Fatal error: Call to undefined function MgInitializeWebTier() in C:\Program Files\MapGuideOpenSource\Server\RepositoryAdmin\cli_listfiles.ph
p on line 46
so i added (scuz my php knowledge)
with include '../../WebServerExtensions/www/mapadmin/constants.php';
and got
Fatal error: Cannot redeclare class mgservicetype in C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\constants.php on l
ine 192
any idea?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071117/81a2516a/attachment.bin
