[mapguide-users] Change shape of polygon...
Keiko Takagi ke-takagi at trk.apptec.co.jp
Wed Nov 21 05:54:10 EST 2007
Maciej,
It is possible to indicate or show our code for adding a new vertex on
existing polygon. Before do that, however, we want to know what you are
looking for whether technique for adding new vertex into existing polygon,
or solution for writing back to postgresql database. That is because our
plug-in library has just completed and won't be opensource.
Are you going to do this on MapGuide or postgis anyway?
We are not sure if this adding vertex should/could be done by one postgis
function.
Regards,
Keiko Takagi
APPLIED TECHNOLOGY CO., LTD.
http://www.apptec.co.jp
Maciej Skorczewski wrote:
>hi Keiko!
>That is great what you are doing...this solution (plug in) is very
>await for all MG user...
>I try make my soluton who base on postgresql database (whit postgis).
>Now i can
>1. add new object (point,line,polygon)
>2. move it on the map.
>3. change shape of added polygon...but....i still have problem whit add
>new vertex. I think that is only postgis function who simply add new
>vertex to existen polygony (still no results)
>i try to put my aplicaton on www.
>it is posible to show/get yours code of this aplicaton?
>I thing that MGOS sould to try add ability like draw,edit shape,line
>etc...as you know many off user(clients) wants to edit (in simply
>approach they data whit internet browser.)
>Keiko Takagi pisze:
>> Maciek and other mapguide users,
>> We, APPLIED TACHNOLOGY CO., LTD, will release the ad-in library for MapGuide
>> Opensource 1.2/ Enterprise 2008, which enable to edit features, including
>> change the shape of polygon, line string, and etc. We are sponsor of OSGeo.JP
>> (http://www.osgeo.jp)
>> If you are interested, you may try our demonstration model. Please access to
>> the following site.
>> http://122.218.96.46/MGAid/main.aspx
>> At this point, our contents and library are written in Japanese. Please
>> refer the attachment to help your transaction. (We may release this in
>> English in the future.)
>> Be noticed that due to the problem of MapGuideOpensource/FDO, data source
>> that can write-in is restricted.
>> The followings are ploblems that we currently have on creating our library.
>> We would be greatful if anyone could find those solutions out.
>> -How to determine whether a property is null
>> http://www.nabble.com/How-to-determine-whether-a-property-is-null-tf4427116s16610.html#a12629044
>> -How to Display MultiGeometry
>> http://www.nabble.com/How-to-Display-MultiGeometry-tf4486202s16610.html#a12793265
>> -restrictions for LayerDefinition
>> http://www.nabble.com/restrictions-for-LayerDefinition-tf4709356s16610.html#a13462555
>> -inserting a feature into SHP feature source
>> http://www.nabble.com/inserting-a-feature-into-SHP-feature-source-tf4573875s16610.html#a13055639
>> Best regards,
>> Keiko
>Maciej Skorczewski
>www.procad.pl
>_______________________________________________
>mapguide-users mailing list
>mapguide-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapguide-users
