SUSPECT: RE: [mapguide-users] Printing
Jason Birch Jason.Birch at nanaimo.ca
Wed Nov 21 13:23:28 EST 2007
Hi Dennis,
The main osgeo wiki (wiki.osgeo.org) is different technology than the
wiki in the MapGuide Trac instance, and does use OSGeo IDs.  We don't
have single-sign-on though, so if you want to log in to the MapGuide
wiki, you have to click on the "Login" link under the search box and log
in there, not through the main OSGeo web site.  And you have to log in
every time you visit the site; it doesn't remember your credentials.
I'd be happy to post the zip and a description if you want to email it
to me offline.  My tech group just started allowing zipfiles through
again, so maybe I'll get lucky, but maybe not.  If not, I'll reply with
FTP details you can use.
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonio,
Dennis (Aviation)
Sent: Wednesday, November 21, 2007 09:38
To: MapGuide Users Mail List
Subject: SUSPECT: RE: [mapguide-users] Printing
Jason,
I have just read this:
The following services do not yet use the central OSGeo userid.
*	Wiki <http://wiki.osgeo.org/> : The main OSGeo wiki uses it's
own userid list for those wanting to edit, but it is easy to signup for
a wiki userid. Please make sure to add your email address to the
appropriate field because it is used to verify you are a real person.
Before that it is not possible to edit the Wiki.
*	Shell access to the telascience blades used for various project
services (ie. buildbot.osgeo.org, buildbot.osgeo.org).
*	Shell access to primary OSGeo server - available by special
arrangement with the System Administration Committee
This then explains why I never see .. "logged in as xxx"
... and frankly all this is getting to be a bit much for me.
I do not wish to be forward and impose but why don't I email you the ZIP
and you then can post it? There is a README that explains.
This would also give you a chance to review the contents first.
dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071121/aea527af/attachment.html
