[mapguide-users] Printing
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Wed Nov 21 12:37:34 EST 2007
Jason,
I have just read this:
The following services do not yet use the central OSGeo userid.
* Wiki <http://wiki.osgeo.org/> : The main OSGeo wiki uses it's
own userid list for those wanting to edit, but it is easy to signup for
a wiki userid. Please make sure to add your email address to the
appropriate field because it is used to verify you are a real person.
Before that it is not possible to edit the Wiki.
* Shell access to the telascience blades used for various project
services (ie. buildbot.osgeo.org, buildbot.osgeo.org).
* Shell access to primary OSGeo server - available by special
arrangement with the System Administration Committee
This then explains why I never see .. "logged in as xxx"
... and frankly all this is getting to be a bit much for me.
I do not wish to be forward and impose but why don't I email you the ZIP
and you then can post it? There is a README that explains.
This would also give you a chance to review the contents first.
dennis
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, November 21, 2007 12:13 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Printing
It's a permissions issue then... I was able to talk my way into admin
rights :)
Odd though, it shows that authenticated users should have wiki create
and modify rights. Just to confirm, when you get that error message,
does it show "logged in as xxx" on the line between the search box and
the bar that has Wiki | Timeline | Roadmap ... ?
I guess I should find out whether you even have edit rights. I've added
a template page for the link below; does it allow you to edit it when
you're logged in?
Jason
I put this into the address bar:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
And the result is:
Not Found
I have zipped up the source and constructed a readme. It is 5.54 MB
(5,813,430 bytes) because I included the iText and IKVM dll's so people
could get started.
dennis
E-mails are automatically scanned for viruses using McAfee.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071121/b70320bf/attachment.html
