[mapguide-users] lost password in upgrade to 1.2
NorTrond trond.tunheim at cellvision.com
Thu Nov 22 07:21:37 EST 2007
I had the same problem when I tried to upgrade from 1.1 to 1.2. I completly
uninstalled 1.1 (killing all process associated with it) and rebooted the
server before installing 1.2. When I had installed 1.2 I could not log into
the webadmin. I looked in the service panel and tried to restart the
Mapguide Server service, but if was hanging!!. I then tried to reinstall the
1.2 with the same result. I also noticed an event i the System log that said
: "Application popup: Microsoft Visual C++ Runtime Library : Runtime Error!"
It seems that the 1.2 Mapguide Service has some sort of bug in it that makes
it chrash and hang, at least on my system.
The end of the story is that I uninstalled 1.2 and reverted back to 1.1. Now
I am waiting for 2.0 to be released.
Trond
Keith Campbell wrote:
> Ryan,
> You might want to try this:-
> http://www.nabble.com/forum/ViewPost.jtp?post=12083605&framed=y&skin=166
> 10
> Worked for me (thanks Jackie).
> Keith
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of north
> Sent: 21 November 2007 15:49
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] lost password in upgrade to 1.2
> Hello,
> I recently uninstalled 1.1, and upgraded to Map Guide Server 1.2.
> The server/webextensions installed fine, but now my Authentication is
> not working.
> My old Administrator password, and the default 'admin' password is not
> accepted by MapGuide Studio, or the webadmin/login.php page.
> Is there any way I can force a reset of the password? Or edit a file
> that has it hard-coded?
> I did this switch on a test server earlier in October, and the password
> was just reset to 'admin'
> But I've just performed the upgrade to the production server, and can't
> access it any longer.
> error message on webadmin: Authentication failed. Please enter a valid
> username and password.
> error on MapGuide Studio: Unable to connect to MapGuide Server. Please
> ensure that the server process is running and firewall rules have been
> set correctly.
> (The server prcess is running, I've also restarted it a few times), I'm
> trying to connect locally, so I don't think there would be any firewall
> issues.
> Any suggestions would be helpful.
> -Ryan
> http://www.nabble.com/lost-password-in-upgrade-to-1.2-tf4850988s16610.ht
> ml#a13879831
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> This message has been scanned for viruses by MailControl - (see
> http://bluepages.wsatkins.co.uk/?6875772)
> This email and any attached files are confidential and copyright
> protected. If you are not the addressee, any dissemination of this
> communication is strictly prohibited. Unless otherwise expressly agreed in
> writing, nothing stated in this communication shall be legally binding.
> The ultimate parent company of the Atkins Group is WS Atkins plc.
> Registered in England No. 1885586.  Registered Office Woodcote Grove,
> Ashley Road, Epsom, Surrey KT18 5BW.
> Consider the environment. Please don't print this e-mail unless you really
> need to.
View this message in context: http://www.nabble.com/lost-password-in-upgrade-to-1.2-tf4850988s16610.html#a13895705
