[mapguide-users] Confusing about reload runtime map
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Nov 22 09:13:19 EST 2007
I also find the naming system quite confusing.
Generally, most map operations can take either a MapName or MapDefinition.
The MapName must sometimes be entered with either a full path, or the
map name.
Sometimes both works, sometimes only one works. I would personally
prefer only the full path.
I don't know which behavior would be classifed as "bugged", but I share
your confusion.
Regards, Kenneth, GEOGRAF A/S
Gunter Becker skrev:
> OK I've found out how to change my code that this works again.
> I had to open the map with the MapName not with the ResourceIdentifier:
> MgMap map = new MgMap();
> MgResourceIdentifier mapId = new MgResourceIdentifier("Session:" +
> MgSessionId + @"//" + MapName + "." + MgResourceType.Map);
> map.Open(ResourceService, MapName); // map.Open(ResourceService, mapId) -
> That's wrong
> But I'm still confused because I don't know what the difference is between
> opening a runtime map with the ResourceIdentifier or the MapName. Until now
> I supposed that these both methods have the same result. Maybe someone can
> explain this behavior. Was it a bug in the former release of MapGuide or is
> it one now?
> Gunter
> Kenneth, GEOGRAF A/S wrote:
>> Are you mixing som 1.1 and 1.2 API's ?
>> There were some changes to how the Layers are stored in 1.2.
>> Make sure your application has the same DLL's as present in the
>> installation
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071122/741a7e97/attachment.html
