[mapguide-users] Mapguide V 2.0
Dave Wilson dave.wilson at autodesk.com
Wed Nov 28 12:57:37 EST 2007
What platform are you installing on?
It's likely under IIS6 (Windows 2003) that the web extension for PHP is missing. I have added an entry for the phpisapi5.dll and the php-cgi.exe.
Regardless of your install platform, under the mapagent virtual directory configuration add .php as an extension and point it to the php-cgi.exe.
Note if you check the configuration under mapguide to ensure that .php is pointing to the isapi dll you may get prompted to propagate a script setting to the mapagent directory. DON'T select the mapagent directory and let it propagate, just lick ok.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Tallman
Sent: Wednesday, November 28, 2007 10:22 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Mapguide V 2.0
Has anyone else had an issue with the bundled IIS .NET install and the mapadmin login?  For some reason or another the php pages don't want to load.  I've installed on a computer where MapGuide has worked before and have also tried the install on a fresh system.
I've been able to check the mapagent index.html page and everything works fine there, so something is up with the php parts.
So is there a step I'm leaving out?  Has this been an issue for anyone else?  Can anyone give me a tip on making this work?
Thanks,
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071128/295a10a1/attachment.html
