[mapguide-users] Mapguide 2.0 Beta1 Documentation
Paul Spencer
pagameba at gmail.com
Thu Nov 29 10:15:09 EST 2007
Hi Bruno,
sorry for the delay. Documentation is being developed, there are a
couple of technical writers working on stuff now.
There should only be 2 css files (style.css seems to have been
removed, I think it was extraneous) that have the following purposes:
jxskin-border.css
This file is copied directly from the Jx project and establishes a
base set of CSS rules that govern all the Jx components. To modify
button sizes, you need to override settings in this file. This can be
done by copying and then editing this file and using the copy in place
of this file, or by adding another file that just redefines the styles
you want to override in your template. Either approach is fine, but
for the mapguide templates, we took the second approach.
maroon_fusion.css
This file has all the overrides for Jx to give the template its
current colour scheme. It also contains any styles specific to this
template.
I think your question about how to change the size of the icons is
going to be a common one, so I am going to start a F.A.Q. and include
that specific question. I will also try to find the right answer
(since CSS isn't my strong point) and post it back to the list :)
The documentation for creating new widgets will likely come a little
later. At this point, you can do what we do, which is to copy an
existing widget that does something similar (from a user's
perspective) and modify it. To do this, it is important to know that
the file name and class name in the javascript file are case sensitive
and have to be identical, and that is the name you use in the <Type>
tag in the ApplicationDefinition.xml file.
Cheers
Paul
On 26-Nov-07, at 2:56 AM, Bruno Scott wrote:
> I'm trying to figure out how to create new templates and it's not easy
> without documentation.
> I would like to change the colors, i know there are some css but
> playing
> with them is time consuming.
> For one template we have 3 css
> fusion\templates\mapguide\maroon\css\jxskin-border.css
> fusion\templates\mapguide\maroon\css\maroon_fusion.css
> fusion\templates\mapguide\slate\theme\default\style.css
> If i want to replace 16x16 toolbar images by 32x32 images, where do
> i go?
> I would also being able to create new components.
> Can we expect a documentation in the near futur?
> View this message in context: http://www.nabble.com/Mapguide-2.0-Beta1-Documentation-tf4874465s16610.html#a13947573
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
