[mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Jo Cook j.cook at OXFORDARCH.CO.UK
Thu Nov 29 13:09:44 EST 2007
Hi Jason,
Great, I'll give it a try. I managed to speed it up by doubling the amount
of RAM my VM was trying to use, and that did seem to help. Worth knowing in
future...
Jo
JasonBirch wrote:
> Wow, that's insane... 12 hours...
> I think I've hacked past it by modifying the Makefile directly.  Now I'm
> going to have to figure out the build system (configure, etc) to make a
> patch.  If you're interested, the last line in each of these sections is
> what I changed in the Makefile in ~/mgsvn/Web/src/CgiAgent/
> mapagent_LDADD = -lACE \
>                  -lxerces-c \
>                  -lMgFoundation \
>                  -lMgGeometry \
>                  -lMgPlatformBase \
>                  -lMgMdfModel \
>                  -lMgMdfParser \
>                  -lMgHttpHandler \
>                  -llib_json
> mapagent_LDFLAGS = -version-info 7:0:0 \
>             -L../../../Oem/ACE/ACE_wrappers/ace \
>             -L../../../Oem/dbxml-2.3.10/install/lib \
>             -L$(top_builddir)/$(map_coordsys_dir_path) \
>             -L../../../Common/MdfModel \
>             -L../../../Common/MdfParser \
>             -L../../../Common/Foundation \
>             -L../../../Common/Geometry \
>             -L../../../Common/PlatformBase \
>             -L../../../Common/MapGuideCommon \
>             -L../HttpHandler \
>             -L../../../Oem/jsoncpp/lib
> Jason
> http://trac.osgeo.org/mapguide/ticket/347
> -----Original Message-----
> From: Jo Cook
> Subject: RE: [mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
> After letting the build run for over 12 hours it finally got through
> that issue... and failed at the missing json file that you filed the bug
> ticket for. Have you managed to get it past this point yet? I was using
> revision 2520, but the later ones don't seem to address your ticket.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS-2-build-freezing-on-Ubuntu-7.10-tf4881293s16610.html#a14031523
