[mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Jason Birch
Jason.Birch at nanaimo.ca
Thu Nov 29 16:12:04 EST 2007
Hmm. Maybe I'll max mine out and see if I can get a faster build :)
I've attached a .patch to the ticket that will fix the Makefile.am with
these changes.
http://trac.osgeo.org/mapguide/ticket/347
The easiest way to apply this patch (and others from Trac):
sudo apt-get install curl
cd ~/mgsvn/Web/src/CgiAgent
curl
http://trac.osgeo.org/mapguide/attachment/ticket/347/CgiAgent_Makefile.a
m.patch?format=raw | patch
Then you just go back to the ~/mgsvn and start again from "Go for the
gusto". Note, I haven't actually tried this without cleaning up
first... not sure how the automake/autoconf thing deals with modified
makefiles.
Some other tools that are useful:
sudo apt-get install subversion-tools
Running svn-clean will remove any files that are not under version
control, so it cleans up nicely after a build. Before running a clean
build, I clear out the /usr/local/ fdo and mapguide directories, run
svn-clean on ~/fdosvn and ~/mgsvn, and then do an svn update.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Great, I'll give it a try. I managed to speed it up by doubling the
amount of RAM my VM was trying to use, and that did seem to help. Worth
knowing in future...
