[mapguide-users] Insert Order In MySql Affect to the
MapGuideSelection?
ary sucaya
ary.sucaya at yahoo.com
Thu Nov 29 15:31:23 EST 2007
http://trac.osgeo.org/mapguide/ticket/313 is not what i'm seeing now. That's another problem of multipolygon. What i don't understand is why the sequence of records insertion affect MGOS select behaviour? If MySql perform geometric operation only on their bounding box, then 'my selection problem' will always happens even i change the sequence of records insertion
Ary Sucaya
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Thursday, November 29, 2007 9:18:39 PM
Subject: RE: [mapguide-users] Insert Order In MySql Affect to the MapGuideSelection?
There is an error in MapGuide with multipolygon selection
but I don't believe that this is what you are seeing, or at least not the only reason...
I think that the primary problem that you are seeing is because MySQL does not perform geometric operations on geometries, just their bounding boxes. My understanding is that someone is working on this for a future MySQL release, but it's a ways out yet?
Jason
Subject: [mapguide-users] Insert Order In MySql Affect to the MapGuideSelection?
I'm not sure either this is a problem of MySql or MGOS 1.2. I created some multipolygon in MySql 5.0.45 and I found a problem regarding to interactive selection:
Some of my multipolygon selected when i clicked my mouse outside it's boundary. Furthermore, MGOS give me a wrong selection result, for example, if i do click on a small multipolygon A then the big multipolygon B would be selected. It's look like the biggest part of small mpolygon A occupied by the big mpolygon B. I made a little bit experiment on this issue. I change the order of records insertion meaning that i insert the smallest multipolygon first and bigger multipolygon subsequently and the problem is gone. This problem doesn't happen if i store the data in sdf format instead of MySql. What's wrong with MySql (or probably MGOS 1.2)?
____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071129/0d718c7d/attachment.html
