[mapguide-users] Insert Order In MySql Affect to the MapGuideSelection?
Jason Birch Jason.Birch at nanaimo.ca
Thu Nov 29 15:18:39 EST 2007
There is an error in MapGuide with multipolygon selection
http://trac.osgeo.org/mapguide/ticket/313
but I don't believe that this is what you are seeing, or at least not
the only reason...
I think that the primary problem that you are seeing is because MySQL
does not perform geometric operations on geometries, just their bounding
boxes.  My understanding is that someone is working on this for a future
MySQL release, but it's a ways out yet?
Jason
Subject: [mapguide-users] Insert Order In MySql Affect to the
MapGuideSelection?
I'm not sure either this is a problem of MySql or MGOS 1.2. I created
some multipolygon in MySql 5.0.45 and I found a problem regarding to
interactive selection:
Some of my multipolygon selected when i clicked my mouse outside it's
boundary. Furthermore, MGOS give me a wrong selection result, for
example, if i do click on a small multipolygon A then the big
multipolygon B would be selected. It's look like the biggest part of
small mpolygon A occupied by the big mpolygon B. I made a little bit
experiment on this issue. I change the order of records insertion
meaning that i insert the smallest multipolygon first and bigger
multipolygon subsequently and the problem is gone. This problem doesn't
happen if i store the data in sdf format instead of MySql. What's wrong
with MySql (or probably MGOS 1.2)?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071129/8ff34fd0/attachment.html
