[mapguide-users] Trouble with rendering service
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Nov 29 16:08:46 EST 2007
I have worked some with the rendering service in .Net.
Is the byte array the size you expect?
Can you post a code snippet with the code you try to run?
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> It's not raising any exceptions?  I have no idea how this works in
> .Net, but in PHP MapGuide uses a custom exception so you can't just
> catch plain PHP exceptions...
> Have you tried looking at the content of the file that is created to
> see if there are any clues?
> Jason
> *From:* Monego, Daniel
> *Subject:* [mapguide-users] Trouble with rendering service
> This creates a byte array, but when I read that array to the page or
> try to save it to disk, it fails to display as an image - in IE it
> displays as a red X, and the file isn't readable by any image viewers.
> I've tried with both "PNG" and "JPG" as type strings, with similar
> results.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071129/e1e8faaa/attachment.html
