[mapguide-users] Trouble with rendering service
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Nov 29 16:44:56 EST 2007
In my experience, the MgByteReader and friends are very hostile in the
.Net environment.
You cannot read more than 8K at a time, and you cannot pass the
MgByteReader to a function without loosing the content.
Most inspections from the Studio debugger also empties the MgByteReader.
I saw a post with working MgByteReader to System.Net.Stream code on this
list. Try searching the posts.
If you do find the code, there is a Wiki with common code stub, and it
would probably be nice to have that code there too.
There should be a size difference between the PNG and JPG, as the PNG
only uses lossless compression.
Regards, Kenneth, GEOGRAF A/S
monegodj skrev:
> The .net api wraps mapguide exceptions in .net exceptions, so it would give
> me a stack trace if it failed.
> There was a big difference between the size of the png and the jpg, so I
> assumed that there had been some significant output, but using a hex editor
> it looks like both are just big blocks of zeros.
> -Dan
> JasonBirch wrote:
>> It's not raising any exceptions?  I have no idea how this works in .Net,
>> but in PHP MapGuide uses a custom exception so you can't just catch
>> plain PHP exceptions...
>> Have you tried looking at the content of the file that is created to see
>> if there are any clues?
>> Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071129/485b8aa5/attachment.html
