[mapguide-users] Change measure dialog
peter56 ibb.scigalla at arcor.de
Fri Nov 30 03:39:05 EST 2007
Hi Kenneth,
thank you for this information and tips. Yes, it runs after restart :-).
Regards - Peter
Kenneth, GEOGRAF A/S wrote:
> That change should do it, but the server caches the file a bit, so a
> restart should make the changes appear.
> You should create a copy of the "en" folder and localize that instead.
> Then you can set the default locale in the server, or on each new
> connection.
> This approach eases upgradse later on.
> Regards, Kenneth, GEOGRAF A/S
> peter56 skrev:
>> Hallo List,
>> can anyone tell me please, how to change teh measure Dialog? I have tried
>> the to change the en file in the localized folder for example from
>> MEASURETITLE            = Measure Distance
>> to
>> MEASURETITLE            = Abstand messen
>> but nothing happend. What is wrong?
>> Thanks in advance.
>> Regards - Peter
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Change-measure-dialog-tf4895719s16610.html#a14042385
