[mapguide-users] Change measure dialog
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Nov 29 16:12:17 EST 2007
That change should do it, but the server caches the file a bit, so a
restart should make the changes appear.
You should create a copy of the "en" folder and localize that instead.
Then you can set the default locale in the server, or on each new
connection.
This approach eases upgradse later on.
Regards, Kenneth, GEOGRAF A/S
peter56 skrev:
> Hallo List,
> can anyone tell me please, how to change teh measure Dialog? I have tried
> the to change the en file in the localized folder for example from
> MEASURETITLE = Measure Distance
> to
> MEASURETITLE = Abstand messen
> but nothing happend. What is wrong?
> Thanks in advance.
> Regards - Peter
