[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
stsampler
guillle at gmail.com
Fri Nov 30 13:21:58 EST 2007
Hi. Try to use mapagent to create the layer. For this, take an XML from other
layer (with getResourceContent) and change it. Later, use setResourceContent
with your xml.
Regards.
Guillermo.
Parvatha wrote:
> Hi
> I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
> and it has got webstudio in that. I am using .NET 2 and able to see the
> sample data.
> My problem is when i try to load SDF data the sytem takes few seconds
> then in data file resources window its showing the file name. But when i
> create one layer and try to give this as data source its not showing any
> feature class and geometry. I dont know what is the problem in loading the
> sdf data. Can anybody please help me to solve this issue.
> I have downloaded the trail version of MG studio preview also. With that
> I am able to do all these things. But basically I want to understand the
> need of webstudio and the limitations. Is it necessary to do everything in
> MG studio only? then what is the purpose of web studio?
> Thanks and waiting for the response
> Parvatha
View this message in context: http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14087757
