[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Nov 30 17:06:03 EST 2007
You should use the "Load Procedures" from within MapGuide Studio.
The load procedures are missing from WebStudio, because the Load
procedures read proprietary data formats and converts them to SDF for
use in the server.
WebStudio is missing the "Load Procedures" and currently an editor for
WebStudio.
What you describe means that there is no spatial data inside the loaded
SDF files.
Please try again with different data. If you suspect that the problem is
with the load procedures,
you can ask Autodesk for support.
Regards, Kenneth, GEOGRAF A/S
Parvatha skrev:
> Can anybody help me to solve this issue in webstudio?
> Parvatha wrote:
>> Hi
>>  I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
>> and it has got webstudio in that. I am using .NET 2 and able to see the
>> sample data.
>>  My problem is when i try to load SDF data the sytem takes few seconds
>> then in data file resources window its showing the file name. But when i
>> create one layer and try to give this as data source its not showing any
>> feature class and geometry. I dont know what is the problem in loading the
>> sdf data. Can anybody please help me to solve this issue.
>>  I have downloaded the trail version of MG studio preview also. With that
>> I am able to do all these things. But basically I want to understand the
>> need of webstudio and the limitations. Is it necessary to do everything in
>> MG studio only? then what is the purpose of web studio?
>> Thanks and waiting for the response
>> Parvatha
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/cd58ae31/attachment.html
