[mapguide-users] Change shape of polygon...
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri Nov 30 17:00:54 EST 2007
I have not yet speed tested the new server.
I can confirm that OpenLayers will download a larger image than
necessary, which is nice for panning, but an overhead otherwise.
Up until now, the 2.0 seems backwards compatible with 1.2.
I think the 2.0 is quite delayed:
http://trac.osgeo.org/mapguide/roadmap
Regards, Kenneth, GEOGRAF A/S
Maciej Skorczewski skrev:
> Hi Kenneth!
> thx for info i will try this ...btw when MG 2.0 will have final relase?
> as i read some post there are problem whit speed...did you try beta
> relase? it is hard to change all existen project into new MG 2.0 ?
> Regards ,maciek
> PROCAD SA
> Autodesk Authorized Value Added Reseller
> www.procad.pl
> > Kenneth, GEOGRAF A/S pisze:
>> Hi Maciek.
>> There is a provider in the Fusion demo, that actually use OpenLayers.
>> If you install the 2.0 Beta, there is a provider in
>> "www\Fusion\lib\OpenLayers.js".
>> With that provider, it is fairly easy to get the Digitizing samples
>> working.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
