[mapguide-users] Change shape of polygon...
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 30 17:35:43 EST 2007
The Trac roadmap is not exactly up to date.  At our last PSC meeting we
talked about the release timeline:
http://trac.osgeo.org/mapguide/wiki/PscMeeting11-01-2007
which is constrained by the FDO timeline to some extent:
http://fdo.osgeo.org/roadMap.html
Based on this conversation, I would guess that we're not looking at a
final release of MGOS until February if all goes well with the betas and
RCs.
So this is a good time for me to stress how important it is to download
MGOS 2.0 beta and take it for a test spin with your existing
applications and data, especially if you have outstanding tickets on
1.2.x.  Given that Autodesk is still writing the majority of the
MapGuide code and are on a fixed development cycle, issues that are not
discovered during this beta process are far less likely to be fixed
quickly.
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Change shape of polygon...
I have not yet speed tested the new server.
I can confirm that OpenLayers will download a larger image than
necessary, which is nice for panning, but an overhead otherwise.
Up until now, the 2.0 seems backwards compatible with 1.2.
I think the 2.0 is quite delayed:
http://trac.osgeo.org/mapguide/roadmap
Regards, Kenneth, GEOGRAF A/S
Maciej Skorczewski skrev:
> Hi Kenneth!
> thx for info i will try this ...btw when MG 2.0 will have final
relase?
> as i read some post there are problem whit speed...did you try beta
> relase? it is hard to change all existen project into new MG 2.0 ?
> Regards ,maciek
> PROCAD SA
> Autodesk Authorized Value Added Reseller www.procad.pl
> > Kenneth, GEOGRAF A/S pisze:
>> Hi Maciek.
>> There is a provider in the Fusion demo, that actually use OpenLayers.
>> If you install the 2.0 Beta, there is a provider in
>> "www\Fusion\lib\OpenLayers.js".
>> With that provider, it is fairly easy to get the Digitizing samples
>> working.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
