[mapguide-users] Exmple of Gdal index xml
Jason Birch Jason.Birch at nanaimo.ca
Thu Oct 4 13:13:25 EDT 2007
Could you please open up the config document, save it out, and send it
to the list as .xml.txt ?
Just to confirm, you're running MGOS 1.2?  What path did you use for the
image files on your server?
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Exmple of Gdal index xml
It seems I spoke to soon.
In MG studio the new feature source is listed, but if you press test
connection you get an error
An exception occurred in FDO component.
Failed to de-serialize the schema mappings from the configuration
Any suggestions
