[mapguide-users] Exmple of Gdal index xml
Gary Morin gary.morin at keygis.co.uk
Thu Oct 4 13:18:17 EDT 2007
Hi
Yes I am using MGOS 1.2
Please find attached xml as requested.
Thanks for your help
Gary
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 04 October 2007 18:13
To: gary.morin at keygis.co.uk; MapGuide Users Mail List
Subject: RE: [mapguide-users] Exmple of Gdal index xml
Could you please open up the config document, save it out, and send it
to the list as .xml.txt ?
Just to confirm, you're running MGOS 1.2?  What path did you use for the
image files on your server?
Jason
It seems I spoke to soon.
In MG studio the new feature source is listed, but if you press test
connection you get an error
An exception occurred in FDO component.
Failed to de-serialize the schema mappings from the configuration
Any suggestions
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:fds="http://fdo.osgeo.org/schemas/fds"><gml:DerivedCRS gml:id="Default"><gml:metaDataProperty><gml:GenericMetaData><fdo:SCExtentType>dynamic</fdo:SCExtentType><fdo:XYTolerance>0.001000</fdo:XYTolerance><fdo:ZTolerance>0.001000</fdo:ZTolerance></gml:GenericMetaData></gml:metaDataProperty><gml:remarks>System generated default FDO Spatial Context</gml:remarks><gml:srsName>Default</gml:srsName><gml:validArea><gml:boundingBox><gml:pos>0 0</gml:pos><gml:pos>425000.48226 455000.56758</gml:pos></gml:boundingBox></gml:validArea><gml:baseCRS><fdo:WKTCRS gml:id="Default"><gml:srsName>Default</gml:srsName><fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter", 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT></fdo:WKTCRS></gml:baseCRS><gml:definedByConversion xlink:href="http://fdo.osgeo.org/coord_conversions#identity"/><gml:derivedCRSType codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType><gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian"/></gml:DerivedCRS><xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:default="http://fdo.osgeo.org/schemas/feature/default" targetNamespace="http://fdo.osgeo.org/schemas/feature/default" elementFormDefault="qualified" attributeFormDefault="unqualified"><xs:annotation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:element name="default" type="default:defaultType" abstract="false" substitutionGroup="gml:_Feature"><xs:key name="defaultKey"><xs:selector xpath=".//default"/><xs:field xpath="FeatId"/></xs:key></xs:element><xs:complexType name="defaultType" abstract="false" fdo:hasGeometry="false"><xs:annotation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:complexContent><xs:extension base="gml:AbstractFeatureType"><xs:sequence><xs:element name="FeatId"><xs:annotation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:simpleType><xs:restriction base="xs:string"><xs:maxLength value="256"/></xs:restriction></xs:simpleType></xs:element><xs:element name="Image" type="fdo:RasterPropertyType" fdo:defaultImageXSize="1024" fdo:defaultImageYSize="1024" fdo:srsName="Default"><xs:annotation><xs:appinfo source="http://fdo.osgeo.org/schemas"><fdo:DefaultDataModel dataModelType="Bitonal" dataType="Unknown" organization="Pixel" bitsPerPixel="1" tileSizeX="256" tileSizeY="256"/></xs:appinfo></xs:annotation></xs:element></xs:sequence></xs:extension></xs:complexContent></xs:complexType></xs:schema><SchemaMapping xmlns="http://fdogrfp.osgeo.org/schemas" provider="OSGeo.Gdal.3.2" name="default"><complexType name="defaultType"><complexType name="RasterTypeType"><RasterDefinition name="images"><Location name="D:\Projects\MGDemo\Raster\"><Feature name="Sd93ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Sd93ne.tif"><Bounds><MinX>394999.25242</MinX><MinY>434999.31774</MinY><MaxX>400000.50226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Sd93se.tif"><Band name="RGB" number="1"><Image frame="1" name="Sd93se.tif"><Bounds><MinX>394999.25242</MinX><MinY>429999.31774</MinY><MaxX>400000.50226</MaxX><MaxY>435000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Sd94se.tif"><Band name="RGB" number="1"><Image frame="1" name="Sd94se.tif"><Bounds><MinX>394999.25242</MinX><MinY>439999.31774</MinY><MaxX>400000.50226</MaxX><MaxY>445000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se02ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se02ne.tif"><Bounds><MinX>404999.23242</MinX><MinY>424999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>430000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se03ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se03ne.tif"><Bounds><MinX>404999.23242</MinX><MinY>434999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se03nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se03nw.tif"><Bounds><MinX>399999.23242</MinX><MinY>434999.31774</MinY><MaxX>405000.48226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se03se.tif"><Band name="RGB" number="1"><Image frame="1" name="Se03se.tif"><Bounds><MinX>404999.23242</MinX><MinY>429999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>435000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se03sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se03sw.tif"><Bounds><MinX>399999.23242</MinX><MinY>429999.31774</MinY><MaxX>405000.48226</MaxX><MaxY>435000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se04ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se04ne.tif"><Bounds><MinX>404999.23242</MinX><MinY>444999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>450000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se04nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se04nw.tif"><Bounds><MinX>399999.23242</MinX><MinY>444999.31774</MinY><MaxX>405000.48226</MaxX><MaxY>450000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se04se.tif"><Band name="RGB" number="1"><Image frame="1" name="Se04se.tif"><Bounds><MinX>404999.23242</MinX><MinY>439999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>445000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se04sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se04sw.tif"><Bounds><MinX>399999.23242</MinX><MinY>439999.31774</MinY><MaxX>405000.48226</MaxX><MaxY>445000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se05se.tif"><Band name="RGB" number="1"><Image frame="1" name="Se05se.tif"><Bounds><MinX>404999.23242</MinX><MinY>449999.31774</MinY><MaxX>410000.48226</MaxX><MaxY>455000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se05sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se05sw.tif"><Bounds><MinX>399999.23242</MinX><MinY>449999.31774</MinY><MaxX>405000.48226</MaxX><MaxY>455000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se12ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se12ne.tif"><Bounds><MinX>0</MinX><MinY>0</MinY><MaxX>0</MaxX><MaxY>0</MaxY></Bounds></Image></Band></Feature><Feature name="Se12nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se12nw.tif"><Bounds><MinX>409999.23242</MinX><MinY>424999.31774</MinY><MaxX>415000.48226</MaxX><MaxY>430000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se13ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se13ne.tif"><Bounds><MinX>414999.36242</MinX><MinY>434999.31774</MinY><MaxX>420000.61226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se13nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se13nw.tif"><Bounds><MinX>409999.23242</MinX><MinY>434999.31774</MinY><MaxX>415000.48226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se13se.tif"><Band name="RGB" number="1"><Image frame="1" name="Se13se.tif"><Bounds><MinX>414999.36242</MinX><MinY>429999.31774</MinY><MaxX>420000.61226</MaxX><MaxY>435000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se13sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se13sw.tif"><Bounds><MinX>409999.23242</MinX><MinY>429999.31774</MinY><MaxX>415000.48226</MaxX><MaxY>435000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se14ne.tif"><Band name="RGB" number="1"><Image frame="1" name="Se14ne.tif"><Bounds><MinX>414999.23242</MinX><MinY>444999.31774</MinY><MaxX>420000.48226</MaxX><MaxY>450000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se14nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se14nw.tif"><Bounds><MinX>409999.23242</MinX><MinY>444999.31774</MinY><MaxX>415000.48226</MaxX><MaxY>450000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se14se.tif"><Band name="RGB" number="1"><Image frame="1" name="Se14se.tif"><Bounds><MinX>414999.23242</MinX><MinY>439999.31774</MinY><MaxX>420000.48226</MaxX><MaxY>445000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se14sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se14sw.tif"><Bounds><MinX>409999.23242</MinX><MinY>439999.31774</MinY><MaxX>415000.48226</MaxX><MaxY>445000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se22nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se22nw.tif"><Bounds><MinX>419999.23242</MinX><MinY>424999.31774</MinY><MaxX>425000.48226</MaxX><MaxY>430000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se23nw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se23nw.tif"><Bounds><MinX>419999.23242</MinX><MinY>434999.31774</MinY><MaxX>425000.48226</MaxX><MaxY>440000.56758</MaxY></Bounds></Image></Band></Feature><Feature name="Se23sw.tif"><Band name="RGB" number="1"><Image frame="1" name="Se23sw.tif"><Bounds><MinX>419999.23242</MinX><MinY>429999.31774</MinY><MaxX>425000.4
