[mapguide-users] MapGuideOpenSource server crashed
rislam r_islam at erp-bd.com
Wed Oct 3 02:27:46 EDT 2007
We didnot check the bug database http://trac.osgeo.org/mapguide/
Yes the stuff occurs repeteadly..
We are using-
Operating System: windows server 2003 web edition
MapGuideOpenSource : 1.2
Web Server: IIS 6
Scripting Language: PHP 5
Database: postgreSQL 8.2.4
Error found:
- MgResourceDefinitionManager.GetDocument line 476 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
Resource was not found: Library://ID01/Data/SOM_MAPS.FeatureSource
Possible cause of error:
A layer named TEST was included in Map.
TEST layer was created using SOM_MAPS feature source.
SOM_MAPS feature source was deleted afterward.
So the layer became unrefernce/invalid and server crashed.
Solution we made:
We have deleted the layer (TEST) manually and server not crashed yet.
Solution we looking for:
We want to track invalid layers programetically to handle the server crash.
zspitzer wrote:
> have you checked the bug database? http://trac.osgeo.org/mapguide/
> which version of mapguide & OS are you using.
> Is it repeatable? if so it would really be good to file a bug if there
> isn't one already in trac.
> If the server process has crashed, there isn't much you can do. Did
> you xml validate, you can always try validating with the xsd
> z
> On 10/2/07, rislam <r_islam at erp-bd.com> wrote:
>> MapGuideOpenSource server crashed due to some error in layer definition.
>> How
>> we can handle it programmatically.
>> View this message in context:
>> http://www.nabble.com/MapGuideOpenSource-server-crashed-tf4553403s16610.html#a12994177
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> http://zacster.blogspot.com/
> +61 3 9018 5778 (voip via my pc)
> +61 405 847 168 (aussie moible)
View this message in context: http://www.nabble.com/MapGuideOpenSource-server-crashed-tf4553403s16610.html#a13013526
