[mapguide-users] RE:Viewer sample application problem
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Oct 8 08:57:00 EDT 2007
I have seen installations where the FCGI is broken.
Try using this link instead:
http://localhost/mapguide/mapagent/mapagent.exe?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=MapDefinition&DEPTH=-1
Also, MapGuide EP is using another path:
http://localhost/mapguide2008/mapagent/mapagent.exe?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=MapDefinition&DEPTH=-1
Regards, Kenneth, GEOGRAF A/S
rudy.pavan skrev:
> Hello Andy,
> if I refresh my browser the situation doesn't change.
> The other sample application (ajaxviewersample.aspx) have the same
> problems.
> I've another problem: when I try to load
> http://localhost/mapguide/mapagent/mapagent.fcgi?
> ://&TYPE=MapDefinition&DEPTH=-1 (for testing the MapAgent) the
> response is "page not found"
> Note: - I've installed MGOS (on Windows 2003 Server EE R2 with IIS
> 6.0) using the installer programs
> - http://localhost/mapguide/mapadmin/login.php is ok
> - http://localhost/mapguide/mapagent/index.html is ok
> Rudy
> If you refresh your browser, does the full web layout and map load
> that
> time? I still often see this problem with the web layout only
> partially
> loading. Does the other sample application work for you
> (ajaxviewersample.aspx)?
> Andy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
