[mapguide-users] GetCapabilities with wrong IP
Zac Spitzer zac.spitzer at gmail.com
Mon Oct 8 10:33:01 EDT 2007
i had the same problem, first tried editing the config file, that
didn't work, then the admin... then after a while it updated to the
new value
On 10/8/07, julienltr <julienleture at hotmail.com> wrote:
> Hi,
> I have the exact same problem with the WMS GetCapabilities.
> You can take a look
> http://www.nabble.com/WMS-%3A-mapagent-doesn%27t-reflect-the-mapadmin-configuration-tf4497061s16610.html#a12824717
> here  but no awser...
> At least, I'm not alone ;)
> Zedler, Jörg wrote:
> > Hi,
> > sending GetCapabilities to MapGuide-Server, I got the right XML, but the
> > address of the server came with localhost and not with the real IP or
> > Servername.
> > Output of GetCapabilities:
> > <GetMap>
> > <Format>image/png</Format>
> > <Format>image/jpeg</Format>
> > <Format>image/gif</Format>
> > <DCPType>
> > <HTTP>
> > <Get>
> > <OnlineResource xlink:type="simple"
> > xlink:href="http://localhost:8008/mapguide/mapagent/mapagent.fcgi?"/>
> > </Get>
> > </HTTP>
> > </DCPType>
> > </GetMap>
> > In serverconfig.ini all IP-Addresses are correct.
> > What can I do, to get the GetCapabilities-Output with the real IP?
> > Thanks for any answer
> > Jörg Zedler
> > INFOKOM Gütersloh AöR
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/GetCapabilities-with-wrong-IP-tf4586438s16610.html#a13096104
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
