[mapguide-users] GetCapabilities with wrong IP
Thomas M. Tuerke
thomas.m.tuerke at autodesk.com
Mon Oct 8 11:19:11 EDT 2007
Verify that the server config is functioning. Examine the actual config file on your server installation; look for the file
.../Wms/OgcWmsService.config.awd
And see what's present at around line 39. You should see
38 <!-- The URL elements. Change to suit, as this is reported -->
39 <Define item="SERVER_NAME">localhost:8008</Define>
40 <Define item="SCRIPT_NAME">/mapguide/mapagent/mapagent.fcgi</Define>
... or something similar for these two definitions. This is what the WMS component is using to generate WMS responses, so if they're wrong, you'll need to modify them.
Definitions on line 25-36 should also be set, but these are informational metadata, not used to build the URL. Lines 42-46 should not be modified.
(Note that the line numbers are keyed off the default file as seen at
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
and your line numbers may vary, based on prior modifications.)
HTH
- Thomas
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of julienltr
Sent: Monday, October 08, 2007 6:00 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] GetCapabilities with wrong IP
I have the exact same problem with the WMS GetCapabilities.
You can take a look
http://www.nabble.com/WMS-%3A-mapagent-doesn%27t-reflect-the-mapadmin-configuration-tf4497061s16610.html#a12824717
here but no awser...
At least, I'm not alone ;)
Zedler, Jörg wrote:
> Hi,
> sending GetCapabilities to MapGuide-Server, I got the right XML, but the
> address of the server came with localhost and not with the real IP or
> Servername.
> Output of GetCapabilities:
> <GetMap>
> <Format>image/png</Format>
> <Format>image/jpeg</Format>
> <Format>image/gif</Format>
> <DCPType>
> <HTTP>
> <Get>
> <OnlineResource xlink:type="simple"
> xlink:href="http://localhost:8008/mapguide/mapagent/mapagent.fcgi?"/>
> </Get>
> </HTTP>
> </DCPType>
> </GetMap>
> In serverconfig.ini all IP-Addresses are correct.
> What can I do, to get the GetCapabilities-Output with the real IP?
> Thanks for any answer
> Jörg Zedler
> INFOKOM Gütersloh AöR
> mapguide-users mailing list
View this message in context: http://www.nabble.com/GetCapabilities-with-wrong-IP-tf4586438s16610.html#a13096104
